New glowplugs and relay. Still not working - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-29-2011, 03:10 PM Thread Starter
bdpprocessors's Avatar
Send a message via AIM to bdpprocessors
Ive been having long cold starts latley. So i replaced all my gp's and my gp relay. Im still having cold start problems.
So i tested the relay and its not sending power to the gp side. The two small ports are always reading 12v even when the plugs should be warming up. Where one port should be 12 and the other should be negative. Correct?
My question is. What controls the duration of the glowplugs. In my diesel jetta the coolant sensor determines the duration. Or if their even turned on at all.
Is it the same on my truck?
1996 f 250 2wd
diy intake
diy propane injection
muffler and kitty gone!
ranchands front and rear
single 5 inch miter cut chrome stack
BURNIN B-100 biodiesel
300 hp 1.9l tdi check it out on tdiclub.com
bdpprocessors is offline
post #2 of 4 Old 02-06-2011, 03:24 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
So i was having serious cold start problems where i could only get my truck to start with plugging it in every night... I went through everything... GP's, GPR, harness, ect... Then went out one morning and all i got was a click... Checked battery's, solenoids, cables, still nothing... Changed the starter and now it cranks faster than it ever has...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #3 of 4 Old 02-06-2011, 04:07 AM
IMQDZLA's Avatar
The PCM controls the operation of the glowplugs. The stock program in my '95 is TEE5, which operates the glowplugs for a full cycle regardless whether the truck is warmed up or not. In my chip, I have TDE1 programming, which causes the glow plugs to cycle completely when the engine is cold, but will not cycle them when the truck is warmed up.
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD,
35X12.50X16.5's, LS 4.10's, Air bags front and rear, PS 2000 propane, TYMAR intake, 1.0AR turbine housing, gutted EBPV, downpipe, 5" exhaust system, DP chip,
Autometer gauges, Fumoto valve, Tru-Cool, HX mod, Tricumulator springs, Sonnax valve, 4R100 pan, Magnefine tranny filter, reverse shackle kit, Big_Fig power pedal.
I'm not affilitated with the vendor "Quadzilla" in any way.
IMQDZLA is offline
post #4 of 4 Old 02-16-2011, 05:36 AM
StrokeHim's Avatar
I am also experiencing problems starting the truck without plugging it in overnight. Your saying after replacing the starter your problems were solved? I have checked the GPR and it is good, but I also heard you can ohm out the GP's through the UVC harness...Is that true? anyone know?
'95 F-350 Reg. Cab, LB, SRW, 4x4
Goodies- AFE stage II (only owned truck since 2/2011)
Coming Soon- 4 inch turbo back, turbo (dominator 66 possibly), stage I injectors, fresh paint, the list goes on....
StrokeHim is offline
