Rough idle, smoke, low mpgs
My 95 PSD just rolled over 193,000. Every time I start it, it lopes pretty bad until I step on the go peddle; after that it smooths right out.
The fuel economy isn't the best, on a recent trip I got 14.5 on one tank, and 17.3 mpg on the other. Both were at highway speeds, one with more passing. At one point I got 20/21 mpg. The last symptom is a good deal of white smoke on cold starts, followed by a time period of some translucent blue smoke. I recently replaced the GPR and changed the oil. What next? Plugs? Injectors? Thanks in advance for the help guys! -Nate |
*the 20 MPG was just after I purchased the truck...
On the bright side I did get a new torque converter, transgo shift kit, solenoid pack and full rebuild for 1000 bones.
Can anyone help with the engine woes? -Nate |
The Mileage woes continued this weekend. With an average of around 15.5 MPG. Also noticed a fairly large spot of diesel under the truck this morning. Could it be that these rough starts and poor economy numbers are being caused by a leaking fuel pump or fuel bowl?
hanging around for info, I also have a 97 OBS, I think the EBPV is acting up.....
Just ordered a full fuel bowl o-ring kit from Guzzle aka DieselOrings.com. Also bought a new fuel pump and all of the hoses and fittings. Hopefully one of these things will solve my leak! Am I on the right track???
All is well. I rebuilt the bowl, replaced the pump and replaced all the soft lines. Also blew out the Exhaust Back Pressure valve. I never saw more than 13lbs of boost at wide open throttle before. After getting the truck put back together I can now get 19lbs of boost! I haven't noticed more pep, but the throttle response is a little better.
I don't know what caused the increase in performance, but I am happy with the results! Now to see if the mileage increases. Still the hard starts though. -Nate Last edited by MustBurnOil; 02-03-2011 at 01:33 PM. |
Im out of ideas guys! I still have a leak in the valley. What to check next?
check all the fuel lines? theres also a TON of orings on the fuel bowl, which ones did you change??
Got the bowl rebuild kit from DieselORings.com, also changed all the soft lines. I didnt change the banjo bolt crush washers, but the old ones didnt seem too bad. Any tips on looking for the leak?
