97' F350 230,000 being a pain in the...runs and dies - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-28-2010, 12:09 PM Thread Starter
First post for me. I hope someone may be able to help me from their own past experience. Over the last year or so the truck will be going down the road and jerk or die once or twice in a row and then fire back up without doing anything and keep on going down the road with no other symptom for a month or months. Recently it got to the point that it would die and not come back on. I would pull over, shut key off and then it would restart. Then this turned into it dying and not wanting to restart for 10-30 minutes. While its not wanting to start the "wait to start light" does not work. When the wait to start light comes on again it will fire everytime and drive like a dream for sometimes as little as 3 minutes and sometimes as long as it takes to get back home. A week ago I unhooked batts and put a new IDM relay in. It ran like a top for 200 miles but has sense started to do the same thing again. Seems like something electrical to me. IDM, PCM? Any suggestions. I just had ford put a new CPS in (died on my way home from dealer) and I am not blowing any fuses. Just changed oil and fuel filter. After 230,000 miles I am confused why she is being so stubborn.
Conky is offline
post #2 of 11 Old 12-29-2010, 10:48 AM
storkerlovr's Avatar
welcome to the org buddy!!!!!
well i would say cps but you replaced that. and maybe the fuel heater in the fuel bowl but most of the time when that goes the truck will not start at all untill its replaced.....someone else will chime in.
good luck
95 reg cab 4X4 STROKER
< trade for 5 speed???
new E40D
Autometer gauges
Gearhead tunes
EBP actuator deleted but not gutted
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
screw all this I just want a 6.4!!!!!!!!!!!!!!
wish list;
5 speed swap
stage 2 injectors
D66
"there may be snow on the mountain but that doesnt mean theirs no fire downstairs
storkerlovr is offline
post #3 of 11 Old 12-29-2010, 03:40 PM Thread Starter
Still Working on it....
Thanks for the reply and the welcoming. I am a huge blue oval guy who has never been left on the side of the road until last Monday. I am glad to get some response on here I was wondering if it was even going to happen. I had one other response on another guys thread. He suggested fuse #30 under the dash may be lose or getting a bad connection. He had that problem with the same symptoms as I. Its got to be something simple. I don't see how it can run so perfect one minute and not at all the next. And what ever it is, is directly tied into the wait to start light circuit. Cause when the truck wont run the wait to start light wont work either.
Come on Robert WhiteFORD !!!!!
Conky is offline
post #4 of 11 Old 12-29-2010, 04:30 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
PCM. the dead give away is the WTS light not working
Trucks and parts............
kanuck15 is offline
post #5 of 11 Old 12-29-2010, 07:40 PM
ryandamo's Avatar
scan it for codes, i hate that that is the generic answer for everything but you will get an immediate answer in a situation like this
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #6 of 11 Old 12-30-2010, 06:27 AM
bondsman's Avatar
Like mentioned above. Fuel bowl heater. Disconnect it.. It could be going bad, shorting enough to draw power from the PCM without blowing the fuse. See if that helps you out. It is free also... Just disconnect and tape it up and give it a go.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
post #7 of 11 Old 12-30-2010, 08:49 AM
Chop's Avatar
I'm with Bondsman on this one,It's concievable that the element is touching enough to give this condition and yet not blowing this large fuse.When the wait to start lamp does not display the pcm is not powered!
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #8 of 11 Old 12-30-2010, 12:59 PM
yeah try unplugging it buti kinda though that once the heater shorted togeather you had a dead truck untill it was unplugged or replaced. not that tempermental stuff
new E40D
Autometer gauges
Gearhead tunes
Push button start
TC lock up switch
DIY with 6637
3.5in DP
5in MBRP
315/75/16 M/T ATZ
3:55
smoked lights
herculiner
10inch PRO JL
20%tint
wish list;
5 speed swap
stage 2 injectors
D66
post #9 of 11 Old 01-05-2011, 08:08 AM
freedomisntfree's Avatar
Send a message via Yahoo to freedomisntfree
subscribing.....
97 2wd ZF 5 (trashed the auto)
3" MBRP Down Pipe
Straight muffler
DIY Intake
TS Tuner
gauges coming very soon
freedomisntfree is offline
post #10 of 11 Old 01-10-2011, 11:49 AM Thread Starter
I will try the fuel bowl heater, but the occurance frequency and the fact that it comes back on whithout ever blowing the fuse is making me think more about the PCM. Is the fuel bowl heater element the thin metal ring directly under the fuel filter with the little round things hooked to it on the bottom side of the ring??
And I put a code reader on it and it had no codes. And I have never had the CEL come on. I am wondering...if the PCM is the culprit would it throw a code for itself?? I would think if it was going out there would be no code.
Thanks for all of the suggestions. I will definitely repost when I finally figure out the problem !!!
Conky is offline
