Truck won't syart
Got a 96 ford 7.3L edge programmer set to extreme also have 4" turbo back and afe cold air intake.. Two days ago true to start my truck noticed gauge read batteries were low.. Fully charged them.. Guage says there still low and truck won't start and no click no crank.. Key turns nothing happens.. Appreciate yours guys help thanks..
grounds? also any dash lights? headlights? dome light?
Fuses are all good and headlights come on wts comes on and dome light also
alright id check 3 things. A) the starter solenoid on the fender. B) the wire that goes from that solenoid down to the starter, its a small wire. C) the main power wire down to the starter off the battery
Okay I'll check them and clean them up thanks man
No problem, keep us updated on what happens
I testes te lines the big line has power of course coming from the battery and the small line non r getting any power to them when I turn the key to run.. I also hear a small click noise coming from under the hood
well that small line is what sends the signal to the starter so it will only have power when you are cranking or trying to
So I cranked it and nothing happened. Seems like if te solenoid could be out then.. Also what do u think that small click was sounded like it was coming from around my intake manifold
thats the glow plug relay, if its clicking its fine. you could try using a wrench and jumping the starter solenoid and seeing if it goes. if so the solenoid is bad
