Torque converter possible failure
Cross post from drivetrain forum, but how can you tell if your Torque converter is going bad, and
Can anyone recommend a good mechanic/shop in N. Dallas/Frisco/Plano TX. Thanks Truck is starting to get undrivable especially when it is cold. tranny shifts fine, jsut has a random wierd ratteling sound out of the tailpipe, and has started shuttering /losing forward momentum now with the sound only going uphill when it is cooler here (sub 40) 2000 f250 7.3 |
EBPV maybe? Are you familiar with it?
No I am not.
I assume that has to do with exhaust. back pressure valve??? |
Just read a little on the EBPV and I don't think that is it. It sounds more like a rattle or shake than a whine or belt slipping. Also it feels more like a loss of power or slipping than a brake to me. The rattle also occurs when it is warm, just doesn't happen when driving. Only when in park.
Just in case how do I disable the EBPV? Just unplug it? |
Unplugging it is one option. I haven't done it myself, but I understand it is plugged in near the base of the turbo housing. Guys also remove the valve. Others manually wire it and use it as an engine brake, or manually engage it for warm-ups. |
