Exhaust sounds - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-05-2010, 11:44 PM Thread Starter
Exhaust sounds
96 f250 sounds like there is air blowing out of the exhaust pipe (whisting sound) It dosent do it at idle and at high rpm's (once turbo spools) the sound dosent stop at all untill i shut it off for a hour or so. Its infrequent very random. possibal turbo problem???
ALASKANPOWERSTROKE is offline
post #2 of 2 Old 12-06-2010, 05:05 AM
ryandamo's Avatar
it is thte exhaust back pressure valve, it is right after the exhaust housing on the turbo and it closes when the engine is cold to warm it up faster. if it is staying on to long, the tube going to the exhaust back pressure sensor may be clogged with soot. It is near the passenger side exhaust manifold and goes up to the front of the motor and looks like a brake line. you can also simply unplug the valve under the compressor wheel of the turbo.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
