FPR spring broken. need help soon - Ford Powerstroke Diesel Forum
Old 11-29-2010, 09:55 PM
My pickup has been starting slower then it shoud lately so I pulled the spring out and is was broken about half way up. I need to know what sping to get or figure something out. It is starting too get colder up here and i need to fix it fast. Thanks
Old 12-01-2010, 02:17 PM
Aftermarket spring
You could try this:
GDS Fuel Spring
Old 12-01-2010, 03:59 PM
I live in a small town but we have a Napa. can i order one there and if so i need to know what one to order? if so what part #, spring tension or size. i have lost the end that broke off so i can compare it now.
Old 12-03-2010, 06:06 PM
FPS? Fuel pump spring?
Old 12-03-2010, 06:09 PM
CRAP!! Just read it again. what is this spring?
Old 12-04-2010, 06:36 AM
It is the IPR (injector pressure regulator) spring that is located in the fuel filter bowl assy.
A common mod is to shim the spring with a bb (from your kids red ryder). The purpose is to raise the injector fuel pressure.
Apparently Ford sold a stronger version of the spring for Cali trucks, but it is no longer available.
GDS calls it a fuel spring which is a bit confusing.
But it is interesting to note that they measured how much the stock spring degrades (looses strength) over time, which probably explains why someone with an older truck would see a difference by adding the bb shim.
Make sense?
Old 12-04-2010, 07:24 AM
I just need the spring that is supposed to go there.
Old 12-04-2010, 07:46 AM
This is the spring that you need.
GDS Fuel Spring
Otherwise go to Ford.
Old 12-04-2010, 04:20 PM
thanks for answering my ? yea kinda makes sense. ill need to see it to understand it.
Old 12-04-2010, 05:19 PM
I heard that you are not supposed to have your fuel pressure run over 80 psi or you will ruin every seal in your fuel system.
