Water In Fuel Light - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-18-2010, 05:14 PM Thread Starter
Water In Fuel Light
My light was on forever, figured it was a bad sensor. While working on some other stuff up top I rebuilt the fuel bowl and cleaned all hoses and connections and replaced the sensors and the pre-heater. After all that damn light came right back on. Odds of getting a bad Motor-Craft sensor are low. Anyone have ANY ideas? Also I always run additive (used to use power services but now use the one from Ford) and open the drain valve for a few seconds about every 1000 miles or so. Even then light still comes on!
DrMartiniX is offline
post #2 of 2 Old 11-18-2010, 05:17 PM
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
try using power service again it happened to my 2006 i use power services diesel clean every time i put fuel in my truck it hasnt come back on in a few months, also i let it run real low on fuel till it was just about on e and i put diesel 911 in it filled it up an put power service in it that shut the light off right then an there
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
