Mystery knocking sound...
Ok guys, I have a real head scratcher here!
Symptoms:
So basically, the only time it'll knock is when I'm accelerating in gear, whether it's a 5mph, or 30mph. But as soon as I let off the accelerator it goes quiet. Possible cause:
Any ideas? These symptoms just don't make any sense to me, but something is definitely very wrong under the hood! |
just cause your trans is shifting ok doesnt mean your TC isnt on its way out
Stick or auto? You mention clutch, Joe say torque converter.
What is the frequency of the knock? Does it match the RPMs? Does it sound mechanical like a rod bearing knock, or something in the body like the downpipe hitting the firewall or engine rocking on loose/broken mounts and bumping things? |
didnt even catch he said clutch, good eye.
Well I figured it out, had someone listen to it from the outside and he thought it was coming from the rear end. Popped the cover off the rear differential and all the grease pour out filled with a bunch of busted teeth off the ring and pinion. Fun times. Trailered it off to the shop yesterday as this is beyond my capabilities.
Ah well that isnt cool. Sorry to hear about that. Coulda been worse
