Brake Problem - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-22-2007, 03:32 PM Thread Starter
Brake Problem
I just put new brakes on the front and rear of my '95 f250 powerstroke 4x4. The pedal was a little mushy to start with so I also changed the master. I bled the system over 10 times and the pedal is still mushy and at start up in the morning rock hard. Any sugestions?
Thanks
J
JNyzz is offline
post #2 of 13 Old 06-22-2007, 08:40 PM
7.3 tech, supporter
fordnut85's Avatar
Any bovious leaks?? Did you bench bleed the master?? When you start it in the morning are they hard and get soft as you use them or have they stayed hard since then?? What do your soft lines look like???
just a few questions so we know what we are dealin with
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 13 Old 06-23-2007, 03:34 AM Thread Starter
No leaks at all. Soft lines replaced 1 year ago. Pedal is hard when backing or pulling out of the driveway and then is spongy at the first stop.
JNyzz is offline
post #4 of 13 Old 06-23-2007, 03:36 AM Thread Starter
I did bleed the master.
JNyzz is offline
post #5 of 13 Old 06-23-2007, 03:38 AM
Check your wheel bearings...if they are loose it will do this exact thing. they will be fine sitting there...or if you only go strait foreward....the minute you turn at all though...then it affects it.
mschn99 is offline
post #6 of 13 Old 06-23-2007, 08:14 AM
7.3 tech, supporter
fordnut85's Avatar
yup yup
Duane
10k mod
Idle control mod
Tymar intake
post #7 of 13 Old 06-24-2007, 04:23 AM Thread Starter
wheel bearings seem fine. i took it for a 15 mile drive today and tried pumping the brakes to see what would happen. when i pumped the brakes before a stop the pedal would get hard and slowly work its way down to the floor. after that pedal would remain mushy until i would pump the brakes to get it hard again. anymore ideas?
JNyzz is offline
post #8 of 13 Old 06-24-2007, 06:51 AM
NOVAJOE105's Avatar
Did you replace the rear wheel cylinders?
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
4.10:1 Gears with posi rear
Shimmed FPR
ITP HPX oil crossover line
Cat and mufler delete
LT285/75R16 BFG A/T KO
RECON Line of fire with ice
178RWHP 349RWTQ....JUST THE BEGINNING
IN THE WORKS:
6" Mitre cut stacks
DP F5
EGT, Trans, Boost gauges
Electric fuel system
Other toy
1990 Chevy with a carbureted 454...kinda quick...lolSOLD!!
NOVAJOE105 is offline
post #9 of 13 Old 06-24-2007, 08:20 AM Thread Starter
no. did not replace the wheel cylinders? could that be the cause of a mushy pedal?
JNyzz is offline
post #10 of 13 Old 06-24-2007, 08:22 AM
WEWILLE's Avatar
It could if they are leaking.
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
