97 PS will not rev over 2K??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-28-2010, 10:32 AM Thread Starter
Let a friend borrow truck to rent bobcat. Claims truck was fine when he returned it. I believe him, honest guy. Anyway, days later I got in truck and it was very difficult to start. Finally did, but engine light was on and would not rev over 2K RPM. Limped to O'Reilley and every time they would hit "scan" on the scanner the truck just died. Replaced fuel filter anyways, no difference. Took computer from my 96 PS and swapped into the 97 and same thing. Not filter, not computer. However, check engine light no longer on. Turbo not seized... Hate taking to dealer because they are expensive and I don't trust them anyways. Any ideas would be appreciated.
lift pump is my next thoughts...
Thanks in advance!
Dustin
spunner is offline
post #2 of 7 Old 10-28-2010, 10:37 AM
catlinB's Avatar
try your throttle position sensor??? or cps ? boost sensor?
Catlin...
newest
2002 F-350 Lariat Ext Cab
4x4 auto, 139,000miles
with a super-chip tuner
SOLD
2000 F-250 Lariat Ext Cab
4x4 6 spd
Stock
1996
F-250 4x4 7.3L Turbo(Stock
5 speed ZF
3" Body Lift
Originally Posted by JJFLASH View Post
Lol what kind of frankenstroke did you buy???
catlinB is offline
post #3 of 7 Old 10-28-2010, 01:20 PM
I know it sounds funny but check the air filter, had a mouse build a nest in mine overnight, never thought of checking that but the dealer did. costly easy fix.
a69reddog is offline
post #4 of 7 Old 10-28-2010, 01:22 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
fuel pressure regulator screen?
Trucks and parts............
kanuck15 is offline
post #5 of 7 Old 10-28-2010, 04:42 PM
EBPV stuck shut?
loudmouth is offline
post #6 of 7 Old 10-28-2010, 04:47 PM
97powerstroker's Avatar
Quoted: 14 Post(s)
are you sure your buddy didnt put gasoline in it? just
2002 F-250 7.3 auto CC/SB lariat 116k miles, 6.0 trans cooler the rest is stock.
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #7 of 7 Old 10-29-2010, 10:49 AM
Goldknight's Avatar
Send a message via Yahoo to Goldknight
My friends wife did that to there 94. What a problem that was. Sounded like it was coming apart by the time she got it home. She drove it about 3 miles on the gas mix to get home. We had to flush the tank and fuel system new filter and oil. Put the batteries on a good charger and started cranking 20 sec at a time. I took 10 min of this to get it to fire back up.
Goldknight is offline
