new at this
I was told the this site could answer me some questions. I have a 1997 PSD with an edge programer my problem is when you first step into the throtle there seems to be a surge in power momentarily then it seems to fall off and excelerate like a slugish diesel does. Could this be a fuel supply problem due to the lift pump? It seems to be worse on the higher settings of the programer. Can someone help
I moved this over to the problem section for you, you should get more responses on your questions here, Good luck.
Gord. |
how long has it been since u changed the fuel filter
it could be or a dirty injector check your fuel preasure at the filter it should be like 60 to 70 lbs
check fuel filter and pressure, but it kinda sounds to me to be bad IPR or IPR O-Rings
Also what year is your truck??
It says 97 in the post Fordnut, must have missed it bud.
Gord. |
