EBP sensor tube
Over the last few months I noticed the engine picking up a slight vibration at low RPMs. It wasn’t bad and sort of came and went. With 340k miles I attributed it to age and normal ware.
Well, the other day I pulled into a fuel station and noticed a very rough idle. Before I could wrap my mind around the vibration problem I was engulfed in a cloud of white smoke. Fast forward to today... After reading many threads here I figured the likely problem was a bad injector. I wanted to check the easy/cheap things first so I pulled the EBP sensor tube to check and clean, it has never been removed. Initially I was disappointed because even though it had carbon residue it was far form being stopped up. At this point I was focusing on the tube ends and didn’t really look at the tube itself. When I shot some cleaner in it I was surprised to see it shoot out the side. Anyway the photo is what I found. I hope this is my problem and I ask anyone here with experience, what sort of problems would a hole like this in the EBP tube lead to? Thanks... |
A follow up question.
What function is the EBP feedback signal? |
Replaced the EBP tube and problem solved.
Again, can anyone familiar with the fuel system explain how the EBP sensor is used in the fueling loop? Just curious. Thanks... |
The pcm uses exhaust back pressure in combination with boost to decide how much fuel to inject.
Thanks FDD.
So EBP is a primary reference for fueling and boost is another. Are there any other references used by the PCM for base fueling? |
where is the ebp sensor located?
connects to passenger side exhaust manifold and runs right up to the ebp sensor behind the hpop reservoir.>>>>brian
