ran out of fuel - embarassing.....just plain embarassing
Alright guys, I didn't really want to post this, but I figured its better to ask and be laughed at, than to mess things up worse.
I decided to drive the truck to work today, so I started it to let it warm up, then ran back inside. I got sidetracked helping get my daughter ready to go (to help my wife get out of the house) and forgot the truck was running. When I finally got back outside ~20 minutes later, the truck wasn't running...out of fuel. ![]() I had just filled the front tank a few days ago, but the switch was still on the rear tank. I switched back to the front tank and tried to start it. The engine turns, but no start. A few times it acted like it wanted to, but nothing.What's the procedure to get her going? How bad did I mess up? ![]() Thanks |
Pour some diesel in the fuel bowl, you can just crank on it but it will probably take that mechanical pump a while to fill the bowl. Then its just going to take a lot of cranking to get it going again, and its gonna run like crap until all the air is worked out of the system.
i always spray a little bit of wd-40 into the intake to start it up, it works great.
I'll take a look at it when I get home this afternoon. I just get frustrated when I do stupid stuff. |
I did that to my last truck and tried everything posted with no luck. My fuel pump took a dump when it happend. Not sure if it was coincidence or related lol
I guess I was fortunate.
I put about 5 gallons in the tank, hooked up the battery charger for a few hours and waited, then i cycled the fuel pump a few times, then with the charger on boost, I cranked the truck. She fired up after a few seconds. Didn't smoke too much, but ran like crap. I warmed her up and ran down to fill both tanks. I've been MUCH more careful about checking before I walk off with it running. |
