Turn signals not working - Ford Powerstroke Diesel Forum
Old 10-05-2010, 12:15 PM
Question Turn signals not working
turn signals worked fine all summer, but now with days that are 50-65 and so far rainy they dont work. hazard lights work fine and they light up when the running lights are on. and theyll come on when the turn signal handle is held down over a few minutes. any suggstions?
thanks
steve
Old 10-05-2010, 12:59 PM
Unplug the flasher and check if you are getting voltage at the socket with a test light or voltmeter when you use the turn signal handle. If not, it's probably in the turn signal handle assembly. If yes, replace flasher or it's a wiring problem between the flasher and the bulbs.
Old 10-05-2010, 01:26 PM
thanks man, its only sometimes it doesnt work. but thanks ill check it this week.
Old 10-23-2010, 04:31 PM
I have the exact same issue that just started. On 2005 I think the procedure is to replace the turn signal arm. Still researching.
Old 10-28-2010, 10:56 AM
i just replaced the flasher and she works
Old 11-01-2010, 11:17 AM
Send a message via AIM to High7echRedneck
Also if it happens again check the contacts on the bulb and housing, sometimes corrosion builds up and makes them work intermittently as you described.
