lope at idle - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-27-2010, 03:01 PM Thread Starter
lope at idle
so here and there right after i start my truck she'll lope 4 or 5 times then stop or if she lopes and i tap the trottle it'll stop, so my question is is this going to eventually end up being a problem over time?
1997 F350 XL Regular Cab Long Bed
Boost, EGT Gauges
Edge Evo
3 Inch dp cat ran off
4 Inch Exhaust to 5 inch angle cut stack
K&N Intake
fbr shim
Fresh Paint
10 inch drop center rear bumper
clear head lights
billit grille
33x12.5 AT on 16.5x10 american racing outlaw II
1996 F350 XL Regular Cab Long Bed 5 Speed- Stock
hondariderfolife is offline
post #2 of 15 Old 09-27-2010, 03:11 PM
junkman306's Avatar
Good question. My 99 does the same thing, but more often when I've let off of the accelerator pedal and I'm coasting.
08/1998 Early 1999 Ford F-250 Superduty, 8800lb GVW, 163,000 miles, Extended Cab, 4x4, Auto, 7.3, Leather, CD/Cassette/AM/FM, LT285/75R16 Maxxis MA-751's, 4" exhaust, otherwise stock............. For Now.........
junkman306 is offline
post #3 of 15 Old 09-27-2010, 03:14 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Is it only doing it when the outside air temp is cold?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #4 of 15 Old 09-27-2010, 03:23 PM Thread Starter
na she'll do it when i start it up warm or cold outside and warm or cold engine temp doesnt make a difference
Boost, EGT Gauges
Edge Evo
K&N Intake
fbr shim
Fresh Paint
clear head lights
billit grille
post #5 of 15 Old 09-27-2010, 03:31 PM
superduty4x4's Avatar
When was the last time you changed the oil?
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #6 of 15 Old 09-27-2010, 03:38 PM Thread Starter
2 weeks ago but it did it before and after oil changes
Boost, EGT Gauges
Edge Evo
K&N Intake
fbr shim
Fresh Paint
clear head lights
billit grille
post #7 of 15 Old 09-27-2010, 03:43 PM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Hm, not real sure right off hand. Unplug your ICP sensor and try it.
Mine will romp when i first start it when it is real cold outside. Could also try switching to a 5-40 synthetic on your next oil change. It really helped my truck with cold starts.
BPS President
Jake is offline
post #8 of 15 Old 09-27-2010, 03:45 PM Thread Starter
i was thinking it was something with the fuel system im going to shim the fbr and see if itll happen agian but i do wanna upgrade the entire fuel system soon
Boost, EGT Gauges
Edge Evo
K&N Intake
fbr shim
Fresh Paint
clear head lights
billit grille
post #9 of 15 Old 09-27-2010, 03:48 PM
x2 on unplug the ICP and see what it does.
post #10 of 15 Old 09-27-2010, 05:15 PM Thread Starter
where is that located?
Boost, EGT Gauges
Edge Evo
K&N Intake
fbr shim
Fresh Paint
clear head lights
billit grille
