1997 cylinder contribution test
does it work on 97? using autoenginuity. when i run the test all i get is something about 2 glow plugs at fault. that shouldn't have anything to do with CCT.
yes it works on 97s. 94.5 and up as long it has the obd2 port. and no. cct is injector only.
ha the results for cct are 1and 3 glow plugs voltage low
no perdel option either just cylinder balance. am i supposed to reboot computer when running on different vehicle??
hmm thats weird. but i havent had that error b4
shouldnt have to. i can plug mine in when driving, running in park, or crank the engine up with it plugged in. just tell it to change vehicles when plugging into the other vehicle. |
just went out first time i got engine oil pressure code. then i tried it 2 more times and got test completed successfully. there was no graph or anything . when i went to live data only options for reading cylinders were "Cylinder Misfire1,2,3,4,5,6,7,8,"
