random dying, not starting
got a buddies truck that has been randomly dying, and not starting. been happening irregulalry, sometimes it will die and not start, next time it will die and fire right up, sometime it will run till you shut it off and not fire back up. put new cps in (date code on box was 2006) and it fired right up just fine ran it for a while, shut it off, wouldn't start. its running again now but just a matter of time till it will quit again. anybody that knows more about fords then me have any ideas? any help would be appreciated.
did you guys find the problem? sounds like what mine is doing. i am losing pressure at the air bleed valve on the regulator.
nothing yet, still hapenning, tried putting new weatherpack connection on cps, helped for awhile
what air bleed valve on what regulator? sorry, not familier with this engine.
umm what's the truck?
and what air bleed valve on what regulator? |
sorry, 97 f350 7.3
on side of fuel filter bowl driver side. at least on a 95. i am losing pressure there and no start.
also, when it wont start, the tach wont budge
if the tach is not moving it is the cps and something is causing it to go bad.
after 6 cps's we gave up on that idea
