no flashers - Ford Powerstroke Diesel Forum
Old 09-05-2010, 03:12 PM
no flashers
i just got the truck and the flashers didnt work. i tried changing the fuse and they still dont work any ideas
Old 09-11-2010, 06:35 AM
The flasher relay...it's round (depending on what year, if it's a superduty it's square) and is responsible for the action of the flashing.
Old 09-11-2010, 07:21 AM
If you have burned out bulbs sometimes it won't flash. Change the flasher and if it still doesn't work I would get a test light and see if you are getting power to the flasher when you put on your blinkers from the lever on the steering column. If no power than your maybe your blinker lever on the steering column is defective.
Old 09-11-2010, 01:15 PM
the blinkers work and the round thing in the fuse box i changed twice ill try the bulbs
Old 09-13-2010, 10:17 AM
There are two round things in the fuse box...one on the backside also.
