low power sometimes - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-24-2010, 06:39 AM Thread Starter
low power sometimes
i have a 94 ford f350 turbo diesel 5 speed has 190,000 miles i am having problems when its cold the engine power is not there its like it has a governer on the throttle when it runs 4-5 minutes you can push in the clutch and let rpm's drop to idle them usually when you pick the thrittle back up it will run great sometimes when its running down the road its like you throw a governor on it again and again drop the rpm's down and it clears up an i having turbo or computer problems its like the damper does not open and close right
johnsrods is offline
