reinstalling injectors?
When reinstalling injectors on a 97 7.3 OBS is there a different part # for the 8th injector or does it not matter?
Doesnt matter, just throw them back in there
Thanks......
No problem, if you need any tips on putting them back in, I have a write up in the tech section
Thanks, I have allready reinstalled them. not to bad considering all i have is a giant welt on my stomach from the hood latch
. i still need to figure out why it constantly blows white smoke and has a slight miss when idling, and has no power when i drive it, im completly stumped.
How long or how far have you driven it since you installed the injectors, whenever I do injectors I drive at least 50 miles after to work all the air out
I think ive drivin it maybe 2 miles, i just have this feeling deep down that there is still something wrong. when i say it blows smoke it covers a 1 mile radius when i get on it but it has no power and the boost gauge reeds 10 psi max, i can smell pure unburnt fuel at idle from the exhaust and it just smokes constantly. when we did a diagnostic on it we were able to monitor everything and the only failure was the injectors they were in bad condition, after taking them in for a rebuild i was notified that they were hybrid and that bumped up the bill alot. i know its chipped but i have no idea whats in it and im thinking the tune is not correct, i think i need to pull the IDM and see if theres a chip in there. right now im at a loss. also my buddy said it has a larger pump and said the fuel pressure is correct but im not sure what it was reading, ive also replaced the crank sensor since then.
Im not sure you can chip an IDM. You get air stuck in them and you gotta run them till the air is pushed out. Did you check the oil? And every time i do injectors the exhaust gets coated with oil and takes a while to burn it off.
LOL! i meant to say PCM, im still geting used to diesel talk. im still not quite sure whats wrong with the truck. im going to post a video here in a minuite, thanks for all the help.
