No Brake Lights - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-02-2010, 06:03 PM Thread Starter
No Brake Lights
So...I have a 1995 F350 Powerstroke (as of today), and I have no brake lights. I have turn signals. I have back-up lights (even the ones up above the back window). But I have no brake lights. I didn't have any 15A fuses, so I swapped out the #4 fuse (which was blown, under the dash) for a known good fuse, and I still had no brake lights. All of the underhood and dash fuses (except for the #4) seem to be good. Is there a switch that would kill power to all three brake lights?
sgg93
sgg93 is offline
post #2 of 12 Old 08-02-2010, 06:24 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
sgg93
Only switch that I know of is mounted directly to the brake pedal.
dhanna6powerstroke is offline
post #3 of 12 Old 08-02-2010, 06:25 PM Thread Starter
Is it relatively common for these to go out? 265K miles?
sgg93
sgg93 is offline
post #4 of 12 Old 08-02-2010, 06:27 PM
Mod Newbie
Quoted: 20 Post(s)
sgg93
If that's original, the yeah wouldn't be a bit surprised. Would be my main suspect if all fuses are okay.
post #5 of 12 Old 08-03-2010, 06:49 AM Thread Starter
OK...so I changed the fuses with new ones, and I put in a new switch. I now have constant power on one side of the switch, and power on the other side when the pedal is depressed. But still no lights. I'm at a loss. The bulbs have to be working (since the turn signals and tail lights work). I guess I'll pull the floor matt up and try to trace the wiring all the way back to the tails. It would seem likely to me that there is a cut in the wire for brake lights somewhere between the switch and where the split is to the 3rd brake light.
sgg93
sgg93 is offline
post #6 of 12 Old 08-03-2010, 01:39 PM
do you have tail lights and license plate lights ? check the connectors under the right rear corner near the rear wheel arch, there is also a ground bolt attached to the chassis under/near the connectors, remove it and clean the chassis where the bolt attaches.
OZZYEDD is offline
post #7 of 12 Old 08-03-2010, 01:41 PM
Air Assault!!
MPTonyT's Avatar
Quoted: 5 Post(s)
Send a message via AIM to MPTonyT
Cycle the hazards on for ten seconds then off for ten seconds. Do this twice and your brake lights should be back.
Don't ask me why..... it just works.
2005 Ford F-250 CCSB-Lariat-FX4-SRW
SCT - Tunned By Matt @ GearHead Performance
FICM Tuned by Bill @ Power Hungry Performance
AutoMeter Gauge Kit (Boost, Pyro, & Trans)
Diesel Site Coolant Filtration System
Viper 5901 Remote Start / Alarm
Zoodad mod w/ Stealth Screen
4" MBRP Exhaust
MECP Master Mobile Audio/Video/Security Installer/ ASE A6 Certified
MPTonyT is offline
post #8 of 12 Old 08-03-2010, 09:05 PM Thread Starter
I tried it, and that didn't do the trick. Thanks for the tip though. I'll have my mechanic check it out in the morning when he's doing tie rod ends.
sgg93
sgg93 is offline
post #9 of 12 Old 08-04-2010, 10:34 AM
Mod Newbie
Quoted: 20 Post(s)
Does the truck have tilt wheel? The Explorers and Sport Tracs had issues with a wire pulling loose when the steering wheel was tilted up. They usuall lost the turn signals but you might try moving the steering wheel up and down and see if the lights come on.
post #10 of 12 Old 08-06-2010, 07:19 PM Thread Starter
It ended up being a pinched wiring harness that was caught in the inside part of the steering column. Oddly, when it went to short it blew the brake bulbs (all 3), but the turn signals and tail lights still worked.
sgg93 is offline
