Auto tranny question - Ford Powerstroke Diesel Forum
Old 05-23-2007, 08:35 AM
I noticed on my 95 if you are in drive and get it up to about 2000rpm and start accelerating the rpm drops down probably ~300 rpm and continues accelerating. I assume that this is the tq converter goin into lock up? Is you keep it steady so the revs climb slightly it does not do this. When i put it in o/d it drops down in rpm when it goes in then like a split second later it drops down more. Again i assume the tq convertor is goin into lock up.
Old 05-23-2007, 09:47 AM
Thats Mr. Oil Leak.....
Yes sir. That is the TQ going into lockup.
Old 05-23-2007, 11:33 AM
Probably a real Stupid question, is that good or bad that the torque converter is going into lock-up?
Old 05-23-2007, 11:45 AM
good. That is what it is designed to do.
Old 05-29-2007, 07:56 AM
Thanks for confirming.
