Thump In Front End - 95 F-250 - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-01-2007, 06:07 PM Thread Starter
I have a thump in the drivers side front end. It sounds like a broken shock, but I checked the shock and it appears to be all right. I get the thump whenever I am driving straight and I hit any small bumps in the road. Multiple bumps equals multiple thumps.
I looked the under carriage over and didn't notice anything out of the ordinary. I had the truck up on a lift and checked out the steering and suspension. Everything looked good. I am worried that there maybe a problem with the frame and or it's fasteners.
Any ideas on what to look for? Any known problems with frame attachments breaking?
Thanks
95 F-250 Power Stroke 2 WD
5-Speed Man, Trans,
86,000 miles
Snoopy is offline
post #2 of 15 Old 05-13-2007, 07:35 PM
7.3 tech, supporter
fordnut85's Avatar
Sorry it took so long to get a reply, I would check the radius arm bushings and the axle pivot bushings.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #3 of 15 Old 05-15-2007, 11:33 AM
Texas_Outlaw's Avatar
I agree with FordNut, I have replaced countless numbers of radius arm bushings on customers trucks. Parts are inexpensive and its not hard to do if you feel like doing it yourself.
Blue 1997 F-350 CC 4x4, RanchHand Front And Rear Replacements, Home Made TYMAR, Terd Superchips, IDM Mod, DIY 160's, Hypermax Downpipe, 5" Black Stacks, Gutted EBPV, Sonnex Valve/Tricummulator Springs, 4" SuperLift, 315/75/16 XTR's
Texas_Outlaw is offline
post #4 of 15 Old 06-16-2007, 05:18 AM
WScott's Avatar
Hmm, I get a thump when I am just sitting after I have started it sometimes.
any ideas
WScott is offline
post #5 of 15 Old 06-16-2007, 05:57 AM
Infidel
TexasR.N.'s Avatar
I have replaced just about all of my bushings, shocks, ball joints and still have that "broken shock" sound. So if any one else comes up with a different item to check please let me know.
Craig
Remember Ft. Hood
And never forget who did it
Religion of peace my жопа
Originally Posted by JK23112 View Post
Ah, we can lead a man to knowledge.....but we can't make him think.
TexasR.N. is offline
post #6 of 15 Old 06-16-2007, 06:09 AM
Check how much play you have on the sector shaft of the steering box, sometimes these will be quite loose and can set up a rattle that feels like it is coming from right under your feet when going over small bumps.
grabowskimech is offline
post #7 of 15 Old 06-16-2007, 03:07 PM
7.3 tech, supporter
fordnut85's Avatar
lay under the truck and have a couple buddies jump up and down on the front bumper and look for anything loose.
Duane
10k mod
Idle control mod
Tymar intake
post #8 of 15 Old 06-16-2007, 03:09 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
sounds kinda stupid but check ur shock tower bolts in the frame... they were loose on my truck wit the previous owner and it took him for ever to find wat it was and he felt stupid when thats all it was
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #9 of 15 Old 07-26-2007, 04:14 PM
I had a noise similar to this on my truck and there were several of the rivits fot one of my radius arm brackets pulled partially through the frame. I cut the rivets out and replaced them with 7/16 grade 8 bolts. I had the front end realigned and havent had any more problems.
Jason
95 F350 psd, cc, dually, 5spd, 4.10. Banks Stinger Plus, Quick turbine housing, chip, pyro and boost guages on a-pillar, downpipe, removed cat and muffler. Griffin aluminum radiator with shroud and 2 Spal electric fans.
j.dehn is offline
post #10 of 15 Old 07-26-2007, 06:50 PM
7.3 tech, supporter
fordnut85's Avatar
Jason
Holy crap dude!! I have never seen that one but glad you cought it!!!
Duane
10k mod
Idle control mod
Tymar intake
