NO throttle! PO221 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-22-2010, 03:58 PM Thread Starter
Strokinokie's Avatar
Send a message via Yahoo to Strokinokie
NO throttle! PO221
OK, just got my re-writer in today from EDGE and successfully programmed back to stock. then with the new re-programmer edge evolution i successfully programmed it to extreme. OK started up the truck and ...... no throttle i pulled the P0221 code from the scanner. ok so i pulled the TPS off my 97 F350 and put it on my 95 F350 "the problem one im talking about." Still no throttle! i put the 95 TPS on my 97 and it runs like a champ! The P0221 says "Throttle/Pedal Position Switch B Circuit Range/Performance" my question is where is switch B? Is it the IVS? I know there are 2 sensors on the pedal. any Info would be appreciated! and i know Edge isnt the way to go but im currently in the process of making my own custom tunes and this will have to do until then! any help with the P0221 code would be of much help! thanks
Strokinokie is offline
post #2 of 8 Old 03-22-2010, 10:12 PM Thread Starter
Update! Still no throttle but IVS is in working order i pushed on the throttle and the IVS clicked and with a test light to the maroon wire with a orange stripe it illuminated! i have cleared the codes a couple of times but i have noticed with the key on engine off it will still pull code PO211 after i cleared the DTC's! The truck is a 1995 F350 I have also unplugged the ICP while at idle and it STALLS and dies! like you turn the key off! I have checked all the fuses in cab and under hood they are all good. Oh and the truck is a 5speed! i have read on other posts about no dash and no throttle but i believe they were on automatics thus having to do with the OD switch shorting out or something in the steering column. any help would be awesome!
post #3 of 8 Old 03-22-2010, 11:10 PM Thread Starter
OK so it was a EDGE EVOLUTION program glitch! i used the rewriter once again and i have throttle now! been havin problems with EDGE since i have had a powerstroke! i really need this TS 6 position burner! so i can make my own tunes!
post #4 of 8 Old 03-23-2010, 03:15 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
Just a side note, I've heard a lot of tuners won't even work on a 94.5-95 truck. This may be why it is causing you headaches.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #5 of 8 Old 04-07-2010, 07:46 PM
I have the same code on my 02 7.3, no throttle or dash guages, will post what I find out.
2002 F250 PSD, Diablo predator, 6637 filter, MBRP 4" turbo back, BD trans. valve body, EGT mod., Wicked wheel, foil delete.
Mud Mechanik is offline
post #6 of 8 Old 04-09-2010, 05:14 AM
Turned out to be a short in the steering column on the wire that goes to the on/off button on the overdrive switch on the end of the shift lever.
post #7 of 8 Old 04-10-2010, 07:18 PM
mud mechanik can you explain how you fixed it. i think im having similar problems but it hasnt gotten to the point where the throttle isnt working.
1999 7.3L F-250
397000 Miles @ Last Check
ShoreMan is offline
post #8 of 8 Old 04-19-2010, 05:45 AM
It was actually the overdrive on/off button on the end of the shift lever that was shorted, just open up the steering column and you will see where it has been rubbing.
