Oil Pump Press - Ford Powerstroke Diesel Forum
Old 04-10-2007, 02:07 PM
Send a message via AIM to WTFORD
Oil Pump Press
I PUT A PRESS GAUGE ON BLEEDER PORT AND GOT 0 PSI I KNOW THAT I NEED 500 PSI TO FIRE THE INJECTORS, HAS ANYONE EVER HEARD OF A EDGE FILTER IN THE OIL PUMP
Old 04-10-2007, 04:10 PM
7.3 tech, supporter
Did you ever fill the HPOP resivour??? Can't build oil pressure if it can't get oil.
Old 04-10-2007, 06:42 PM
Hpop Res
YES I DID FILL THE HPOP RES, AND I DO GET OIL THROUGHT THE SYSTEM BUT IT JUST WON'T BUILD ANY PRESSURE :censord: :censord: :censord:
Old 04-25-2007, 11:55 AM
just gona bump it up for ya, good luck!
Old 04-25-2007, 12:35 PM
ADMIN AND TECH
hig pressure pump bad more and likely if you cant get it to build pressure but the reservoir is full
