Cruise control - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2017, 11:28 PM Thread Starter
DustTagg92's Avatar
Cruise control
I have a 95 F-250 HD XLT and the cruise hasn't worked since I got it. When I turn the wheel there is a clicking noise in the column. Since the truck doesn't have an airbag I know there wouldn't be a clockspring. Can anyone tell me where to start looking to try and fix this? Thanks in advance.
DustTagg92 is offline
post #2 of 5 Old 04-20-2017, 03:27 PM
Quoted: 53 Post(s)
Automatic or manual transmission? Have you checked ALL fuses?
madpogue is offline
post #3 of 5 Old 04-20-2017, 10:26 PM Thread Starter
DustTagg92's Avatar
It's a manual trans. And all fuses are good. All lights work except the center cab light on the roof. And the neutral safety switch/backup light switch on the transmission is brand new
post #4 of 5 Old 04-20-2017, 11:24 PM
Quoted: 53 Post(s)
There's no neutral safety switch. Nothing on the transmission controls the cruise.
Try replacing the center stop light bulb. Sometimes when it's burned out, it causes the cruise to disengage when you hit the turn signal, and sometimes it renders the cruise inop completely. I've experienced both, and confirmed it by reading real-time PCM data via AutoEnginuity; on one of our trucks, when the center stop light burned out, the PCM was fooled into thinking the brake pedal switch was closed, which interrupts the cruise.
madpogue is offline
post #5 of 5 Old 04-21-2017, 03:04 AM
Quoted: 25 Post(s)
There are three brass slip rings and three spring loaded contacts that ride on them behind the steering wheel. Check those out. I had a similar situation and one of the wires on a contact had disconnected. I.e. a cold solider joint.
97 F350 XL std cab, zf5, srw, 4wd, & 3.55s
Donaldson, 3" dp, 203F t-stat, ACs & Hydra w/ PHP tunes, DIY 60 gl tank, 6 gl sump, wood box, eFuel/Cat filters, Aeromotive RR, Auber instruments & IDM mod, DIY deer deflector, rear bumper, recessed hitch, KC-TP38r, bellowed up pipes, 6.0 IC & 3" plenums, Bronco overhead console & lower door panels, custom upholstered 40/20/40
MeTo is offline
