7.3 glow plugs for a 1995 - Ford Powerstroke Diesel Forum
Old 03-19-2007, 08:14 AM
Been failing glow plugs and I was wondering what the most common cause of this is and which is the best brand to use.Also I am going to do myself this time,if anyone has any instruction it would be great.Thanks
Old 03-19-2007, 08:35 AM
Greetings Powerstrokers
The link above should help with the install, it's done by Maintain, so thanks goes out to him for the write up. As for the cause, can't help, but I'm sure a tech will be along to help.
Gord.
Old 03-19-2007, 04:14 PM
7.3 tech, supporter
are they all dying on the same cyl or bank?? What is the resistence reading when they fail?? might help to diag. your problem
Old 04-25-2007, 10:03 PM
use the motorcraft zd or zf 11 glow plugs.not sure of the letters.other brands have been known to swell and break off in the cylinder.
Old 04-26-2007, 04:29 PM
be real carfull taking them out, some times thay'll get hot and "bell"or become oval and wont want to come out of the head. just take ur time and be carfull
