fuel in oil - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-18-2007, 02:57 PM Thread Starter
fuel in oil
getting fuel in the crank case. was told is possible o ring around injector . i dont understand if that is possible with oil pressure being so much higher than fuel pressure 95 7.3 newer engine 6000 miles
boat man is offline
post #2 of 3 Old 03-18-2007, 06:30 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
I would think an injector o-ring as well.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360° thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 3 Old 03-18-2007, 07:08 PM
Nuckin' Futz
yep at least an external o-ring on one or more of the injectors...that happened to me except oposite...i had oil in my fuel and they had to replace two injectors which were leaking internally.
Turbodude is offline
