no power and blue smoke - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-05-2009, 06:42 PM Thread Starter
jaysonmore's Avatar
Send a message via Skype™ to jaysonmore
I have a '99 7.3 f350 and i just replaced a bad injector. It has NO power and is blowing blue smoke. I pulled the codes and i got p0470 EGR boost sensor, p1184 EOT sen. ckt perf, p0476 EBP not controllable, p0284 cylinder #8 which was the injector i just replaced. Does anyone know how or what i need to fix to get my truck workin again? Thanks guys
jaysonmore is offline
post #2 of 3 Old 10-06-2009, 03:12 AM
ryandamo's Avatar
what your describing ounds like the ruck inst warming up properly, did this all start when it got cold out? im exactly sure of this but it also sounds like you may have a boost leak or a faulty boost detector, which will cause the wastegate to malfuntion which will cause smkoe and loss of power. Also... therer is a flap in the exhaust caulled the ebpv(exhaust backressure valve) it closes when the truck is cold to aid a cold start. If it is either not closing, it might not warm up as fast and if it is staying closed once its war, exahust gasses cannot properly exit causign loss of power.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 3 Old 10-06-2009, 06:54 AM Thread Starter
jaysonmore's Avatar
Thanks for taking the time to help. No it happened in the hottest time of the year. The check engine light had been on and i noticed a lack of power so i thought it was just an injector. Kept running it 'till one day after just refueling i was at a stop light and it started running really rough and blowin heavy blue smoke so i thought i just got bad fuel. The truck barely had enough power to pull into the parking lot and i ended up towing it home. I replaced the injector and now it runs smoother but still no power and blue smoke.
Thanks again
