truck died now wont start
i got a 97 f350 and i started it up one cold morning and it was fine then i started losing all my power intell it finally died and now it wont start. it just cranks and cranks. i have checked fuse #22 and changed the cam senor still the same thing???? if any could help i would appricate it. thanks
is the oil level full and in good condition ,do you have a way of pulling codes
oil pressure is fine and i ran diagnostic with my edge programer and it had codes P0470 and P0603.
How Do You Know Oil Pressure Is Fine ,if You Are Reading That By The Gauge That Is Low Pressure Oil ,you Can Have Low Pressure Oil
And Not Have High Pressure Oil And Truck Wont Crank ,but By Those Two Codes ,p0470 ,ebp Sensor Code ,wont Cause No Start ,and P0603 Is Just A Pcm Code Set Because Of Using Programmer , You Might Have A Fuel Pressure Issue, Take The Filter Cap Loose And See If Fuel Bowl Is Full |
What about fuel pressure?
i ment oil level is fine. and yes there is fuel getting to the fuel filter.
Gonna Have To Get A Scanner That Will Run Some More Diag ,along With A Fuel Pressure Test, Need To Run Injector Buzz Test To See If Electrical System To Injectors Is Ok ,also Need To Check Igh Pressure Pump Reservir Just To See If Its Full ,but More And Likely If It Wasnt ,should Have Thrown A Code P1211 Or P1212 But Thats Always Not The Case , Pull Allen Head Plug Out On Top Of Reservoir And See If Any Oil Is In I ,has To Be Within Half Inch From Top , If Not Could Be A Problem ,just Some More To Check
May be an HPOP problem, can you get the HP oil pressure checked?
