Runs till get warm then stalls - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-11-2007, 05:17 PM Thread Starter
I have bought a 97 PS and it runs great till the thermostat opens and then it will lose power, turbo won't work and stall out all with in the 15-30 seconds of the thermostat opening. After 1-2 hours it will start again and run till it gets warm. I have changed CPS cheked for fuel in the filter and it pumping also. I am at a loss. There were other post saying the same thing but noone has said how to fix it. please help Thanks
fire145 is offline
post #2 of 4 Old 02-11-2007, 06:03 PM
tubzz's Avatar
IPR o-rings or maybe the ipr it self.thats my geuss
when it dies it won't start back up tell cold again right?
MATCHING COLOR HIS AND HERS PSD!
HIS: 97,F250,
HER'S: 97,f-250,
some bolted on stuff by BDP and tuned by tony wildman
vice President
tubzz is offline
post #3 of 4 Old 02-11-2007, 06:14 PM Thread Starter
Yes it has to be cold 1-2 hrs Help me out ipr? I own a dodge and don't know much about the PS I just bought
fire145 is offline
post #4 of 4 Old 02-12-2007, 04:41 PM
tubzz's Avatar
IPR= injector pressure regulator
it on the driveside of the HPOP (high pressure oil pump) and it is under the fuel bowl.you can fine then on e-bay pretty cheap or you can get a o-ring kit for them.it will be a messy job.you will have about 1qt of oil come out plus you may have to remove the fuel bowl.(that depends on the size of your hands)
here is some part # for you.good luck
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
IPR Injection Pressure Regulator
(Ford) F4TZ-9C968-C (engine serial no. 187099 & before or pump no. 255C92)
(International) 1824982C91 (engine serial no. 187099 & before or pump no. 255C92)
(International) 1833798C91 (All Years ???) latest part number
(Ford) F81Z-9C968-AA (engine serial no. 187100 & up or pump no. 247C91)
HIS: 97,F250,
HER'S: 97,f-250,
vice President
tubzz is offline
