Front and Rear Axle identification - Ford Powerstroke Diesel Forum
post #1 of 23 Old 05-12-2009, 06:13 AM Thread Starter
Ford Crazy!!!
COON555's Avatar
Can anybody tell me what axles I have? The numbers on the front are 5298 and the rear are 5300. Any help would be appreciated. Thanks
1996 OBS F-350, REG CAB, 4X4, E4OD TRANNY
80K MILES
305/75R/16 TSL SUPER SWAMPERS
GAUGES EGT/TRANS/BOOST
TW 6 POSTION CHIP stock/eco/street/extr/tow/htow
3" DP, AND 4" MBRP EXHAUST
6637 DIY INTAKE
DERALE TRANS PAN
TRANSGO TUGGER KIT
DIESELSITE BOOST RELIEF VALVE
IRON BULL BUMER WITH LIGHTS
SD INTERCOOLER WITH BANKS PIPING KIT
COON555 is offline
post #2 of 23 Old 05-12-2009, 11:41 AM
toad's Avatar
Quoted: 16 Post(s)
DON'T HAVE ANY IDEA WHAT THE NUMBERS MEAN BUT ON A F-350 REAR WILL BE A STERLING 10.25" AND FRONT WILL BE A DANA 60. IF YOU WANT YOUR GEAR RATIO THERE SHOULD BE ANOTHER SET OF NUMBERS OR JUST CALL THE DEALER AND HAVE THEM PULL YOUR VIN
toad is offline
post #3 of 23 Old 05-12-2009, 02:42 PM
Chadahootchie's Avatar
f350 have a 10.5 sterling rear
1997 Ford F350 CC LB 4x4
2007 F350 axle/suspension swap
238/100 Full Force Stage 3 Injectors
H2E Turbo
Fully Built Trans with Triple Disc Billet
Tony Wildman Chip
Superduty IDM
5'' Straight Pipe 7'' custom sideways bed stack
Leveled on 37s
Chadahootchie is offline
post #4 of 23 Old 05-12-2009, 11:34 PM Thread Starter
Ford Crazy!!!
COON555's Avatar
So all F350's have 10.25 rears and Dana 60 fronts? I thought some were different. Cool, and thanks!
80K MILES
6637 DIY INTAKE
DERALE TRANS PAN
TRANSGO TUGGER KIT
COON555 is offline
post #5 of 23 Old 05-12-2009, 11:46 PM
justinbaldwin69's Avatar
if its 80-86 f350 it will be different,they have independant front ends,unless its a dually i think
from 87-97 all f250-f350 have sterling 10.25 rear end
hd f250 have a dana 50 up front
anything but a chrysler product
the only thing that runs good on a dodge is the drivers mouth
dodge boys
FORD MEN
justinbaldwin69 is offline
post #6 of 23 Old 05-12-2009, 11:57 PM Thread Starter
Ford Crazy!!!
COON555's Avatar
So do F350's have Dana 60's up front???
80K MILES
6637 DIY INTAKE
DERALE TRANS PAN
TRANSGO TUGGER KIT
COON555 is offline
post #7 of 23 Old 05-13-2009, 08:19 AM
toad's Avatar
Quoted: 16 Post(s)
I think if you get back to the early to mid eightys they use the indepent dana 50 in the front. The superduty you can get either a solid dana 50 or 60. The obs like you have in you pic uses the solid dana 60 front axle. When ford introduced the superduty they changed the ring gear in the rear to 10.5 inches.
toad is offline
post #8 of 23 Old 05-16-2009, 06:12 PM
depending on the year,87-96 f350 has the 60 up front
dodge boys
FORD MEN
post #9 of 23 Old 05-18-2009, 03:08 PM
ZachBoyer's Avatar
I have a spicer on the front of my truck... Ford experemented with the spicer for three years so some trucks have danas and some have spicers so 95 96 and 97 are a guessing game... from what ive been told atleast. But I do know I have a spicer
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #10 of 23 Old 05-18-2009, 08:05 PM
look at your front dif cover,i bet it has dana stamped on it,and it should have a 10 bolt cover
dodge boys
FORD MEN
