H11s vs ARP's? - Ford Powerstroke Diesel Forum
Old 04-02-2009, 09:30 PM
H11s vs ARP's?
On a 7.3. Which one is a better choice?
Old 04-02-2009, 09:48 PM
Send a message via AIM to ford_trck
I was just reading over on the nation last night about this. I think they say the H-11's are stronger but unless your a competition truck the ARP's will be just fine.
Old 04-02-2009, 10:01 PM
Cynic
that is the only thing that needs to be said.
Old 04-03-2009, 11:51 AM
H-11's are on my twinned rig, i think they are the best but like the other guys mentioned arp's are good enough for most.
Old 04-06-2009, 11:51 PM
I fitted the ARP's and had trouble fitting them under the injectors and had to cut them down.
Old 04-07-2009, 05:40 AM
Cynic
I've never seen trouble with arp's under the injectors. The 8 shorter bolts are actually shorter than needed.
Just take your time and use air to blow out/dry out the holes. I haven't had to use a thread chaser on a 7.3, but that wouldn't hurt.
Old 04-07-2009, 05:47 AM
ADMIN AND TECH
ive put several sets in with no issues except for mine , my bolts under the injectors did the same thing , i ground a small section of the injector hold down off
Old 04-07-2009, 07:31 AM
ARP's unless your pushing twins... If you put the right bolts in the right holes you will have no issues with grinding the hold downs...
Old 04-09-2009, 12:11 PM
theres 8 short studs for a reason lol
Old 04-10-2009, 04:31 AM
ADMIN AND TECH
i know there is supposed to be but i pulled mine back out twice and had no shorter ones
