fuel pump question - Ford Powerstroke Diesel Forum
Old 03-25-2009, 08:31 PM
fuel pump question
ok I have the stock setup for fuel, BUT if I put a inline electiric pump like 70gpm or gph whatever as a helper pump will it hurt anything, will it over work the mechanical pump ontop of the motor or will it make it work less ?
Old 03-25-2009, 08:48 PM
Shaking the Bush Boss
I dont think it will. the fuel will pass thrugh the stock pump. I could be wrong though. Thats how it was explained to me.
Old 03-25-2009, 08:57 PM
will it help any???
Old 03-25-2009, 10:13 PM
Good Question
Old 03-25-2009, 10:25 PM
it'll add fuel! I'm planning on removing the stock pump, and upgrading to a SD elec. pump set up.
Old 03-25-2009, 10:27 PM
i mean what if u leave the mechanical OBS pump on and add a small electric pump (until you can afford to change your hole fuel system)?
Old 03-25-2009, 10:30 PM
scuffs *****
Send a message via AIM to Tyler
Only one way to find out.
Old 03-25-2009, 10:35 PM
The diesel engine (not sure about PSD) has a fuel return line off of the (usaly the pump) in this case i would asume the injectors, so that any excess fuel returns to tank. So basicly if u end up putting TOO much fuel to the injectors it should bypass and go back to tank (in theory). I would think that an electric pump before the pickup pump would reduce the strain on it. Just a thought
Old 03-25-2009, 10:36 PM
I aggree with Tyler !! go for it
Old 03-25-2009, 10:49 PM
I think I may the pump iam looking at is 70gph or gpm i cant remember but its only like $60 and it should be fairly easy to put it in-line
