superduty intercooler and stage 1 injectors - Ford Powerstroke Diesel Forum
Old 03-23-2009, 12:49 PM
I am wanting to get the diy Stage 1 injectors.
But not sure if i should add the superduty intercooler first. Is it really needed if you dont do much towing and arent drag racing all the time?
Is there any cheaper aftermarket turbo's that could keep the egt's down with out haveing to go to the extent of the intercooler?
i Have a 97 f250 powerstroke with 4inch exhaust and intake, new transmisson, with a transgo shift kit. thanks!
Any info would help a bunch
Old 03-23-2009, 12:50 PM
a truck
First off do you have guages? Also do you have a chip, if not you need a custom chip otherwise stage 1 injectors will act stock since they have stock nozzles. And yes I would highly suggest adding an SD intercooler if you are doing stage 1s
Old 03-23-2009, 01:03 PM
ya got the ts, is TW the best place to get it reburnt? i saw that you switched to swamps. and yes i do have gauges.
Old 03-23-2009, 01:08 PM
a truck
TW is a good place for sure, swamps is good as well, I just switched to try something different. But yeah without the intercooler and the 1s my egts and boost were way high and the intercooler solved that
Old 03-23-2009, 01:12 PM
do you have a parts list from when you did your intercooler. can i just by the piping from banks and then could i just find a cheap superduty intercooler?
Old 03-23-2009, 01:13 PM
a truck
yep thats what I did, I used an SD intercooler with banks pipes
Old 03-23-2009, 01:16 PM
do you have to get a superduty turbo pedistal for the piping?
a truck
nope, just get the banks pipe kit for 94-97 trucks
Old 03-23-2009, 01:18 PM
ya you wont be sorry. should gain some hp also.
Old 03-23-2009, 01:20 PM
if you dont mind me asking how much did the banks piping end up costing you?
