how to do injectors.. - Ford Powerstroke Diesel Forum
Old 03-21-2009, 03:07 PM
ive never done them on a PSD....all the others but a stroker....well i found some and now i need to know how to do the swap....i know i take off the valve cover and all that but do i have to take my turbo off??? it doesnt look like it but i didnt know...ummm take my old injectors out suck the oil off the pistons and put my stage I's in then torque them down and put the valve cover back on...sound right??? does any one know what they should be torqued to?? also should i change my valve cover gasket????
Old 03-21-2009, 03:15 PM
If it aint a CAT itsa DOG
I don't think you have to take off the turbo. Just the intake tubes and valve covers. Gaskets might not be a bad idea. I'm not sure on the torque spec.
Old 03-21-2009, 03:18 PM
what injectors did u get?
Old 03-21-2009, 04:25 PM
i got some hypermax's that the guy said had the enternals done not the nozzles....
Old 03-21-2009, 04:44 PM
I wouldn't just "suck" the excess oil/fuel outa the cylinders. You take a good chance at hydrolockin, and crackin a head. When i did mine i pulled the glow plugs out, put the new injectors in, tighten them down put the valve covers on (with 2 or 4 bolts). Then turned the motor over. don't worry it wont start. Do that a couple of times then put the glow plugs back in. There's a aritical about it some where around here. I'll try to find it for ya
Old 03-21-2009, 04:54 PM
International Threat
Check the tech files.
i have a writeup on it.
Old 03-21-2009, 04:59 PM
Here, Try this! OBS Injector R&R
Old 03-21-2009, 08:23 PM
Shade tree mechanic
follow that injector r&r and you will be good. valve cover gasket are reusable BTW. and dont be scared, dive in. I never done them before either and i had mine in and out in no time. pretty straight forward once you get into it
Old 03-22-2009, 08:44 AM
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Don't just torque them, they need to be fully seated first!!! Take a deadblow hammer and HIT them in until they change tone. Don't be afraid as they are very durable, Jon at Swamps even did a demostration with an injector solenoid and a small sledgehammer to show how tough the solenoids are.
-Michael
Old 03-22-2009, 08:56 AM
Wow that must be pretty tough. I would have never thought of that and probaly would have yelled at anyone I saw doing it!
