What advantages come from a wicked wheel - Ford Powerstroke Diesel Forum
Old 02-24-2009, 06:15 PM
Send a message via MSN to strokerman12
Really my question is wat improvements will i see from a wicked wheel
Old 02-24-2009, 06:20 PM
reduce turbo surge, spool faster, bad *** sound, no real hp gains
Old 02-24-2009, 07:09 PM
so any extra pounds of boost on the top end rather than the 26 27 i get now
Old 02-24-2009, 07:16 PM
no gains at all for you same wheel you have this is for the SD's. the same wheel you got in your truck no gain just less surge.
Old 02-24-2009, 08:07 PM
You have one in your truck, they are stock. This is a mod for newer 7.3s Unless your stock turbo wheel isnt looking good there is no gain in anything. Same wheel.
Heres my Stock compressor with damage from 300 shot of nitrous nozzle that was to close to the wheel, and a new "Wicked Wheel". Compair.
Old 02-24-2009, 08:50 PM
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Like was said before you already have the same thing as a wicked wheel from the factory. A wicked wheel isn't really an upgrade for a SD truck either, as it flows less air to combat surging. Your OBS truck shouldn't surge with a stock turbo, period.
-Michael
Old 02-25-2009, 03:34 AM
If the SD wheel flows more air than the WW than how much more does it flow? If you were to put on a blow off valve wont that stop the stall, idk about the surge tho.
Mark
Old 02-25-2009, 07:13 AM
Enought to make a stock SD turbo surge vs having an OBS wheel, honestly I'm not sure. But most of the rebuilt OBS and early '99 turbos I see have the factory SD wheel in them.
As for a blow off valve, I don't see a need for one in a stock turbo application. Period.
-Michael
Old 02-25-2009, 09:03 AM
would there be any advantages on putting SD wheel in a OBS.
