6 spd in an OBS - Ford Powerstroke Diesel Forum
post #1 of 20 Old 02-24-2009, 03:51 PM Thread Starter
NOVAJOE105's Avatar
6 spd in an OBS
I have a 95 F250 that is in need of a transmission. It has a E4OD in it now and I have gotten a quote to have it built to withstand whatever I can throw at it but now I am thinking about putting a 6spd in its place. I don't mind rowing gears and I like being able to select my shift points rather than havin a FRED do it for me. Anyone ever done this or know anyone who has?? Any tips or advice would be greatly appreciated. Thanks everyone
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
4.10:1 Gears with posi rear
Shimmed FPR
ITP HPX oil crossover line
Cat and mufler delete
LT285/75R16 BFG A/T KO
RECON Line of fire with ice
178RWHP 349RWTQ....JUST THE BEGINNING
IN THE WORKS:
6" Mitre cut stacks
DP F5
EGT, Trans, Boost gauges
Electric fuel system
Other toy
1990 Chevy with a carbureted 454...kinda quick...lolSOLD!!
NOVAJOE105 is offline
post #2 of 20 Old 02-24-2009, 03:55 PM
Shaking the Bush Boss
CHUCK's Avatar
been along time sinse I have heard anyone call it a FRED!!!!
bump to the top for ya
Chuck
CHUCK is offline
post #3 of 20 Old 02-24-2009, 03:57 PM Thread Starter
NOVAJOE105's Avatar
Thats a daily term for me since I spent 15 years in the auto/diesel field before gettin out of it. Thanks for the bump
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
Shimmed FPR
IN THE WORKS:
6" Mitre cut stacks
DP F5
Other toy
post #4 of 20 Old 02-24-2009, 03:58 PM
dieselmac99's Avatar
well the ZF-5 should be feasible but to do a ZF-6, I believe you need a crapload of work. There was a thread on here somewhere about a month ago. I'll try to find it and post a link.
2000 F250 7.3 ZF6 4x4 EC/LB 5" TBE
2003 Chevrolet LB7 Allison 1000 4"TB
2004 F450 6.0 5R110 9' MM2
2004 F350 6.8 5R110 8' MM2
dieselmac99 is offline
post #5 of 20 Old 02-24-2009, 04:00 PM
and viola!
ZF6 on an OBS
Ha! knew I'd get it!
Hope this helps.
Good luck!
post #6 of 20 Old 02-24-2009, 04:04 PM Thread Starter
NOVAJOE105's Avatar
thanks for finding the thread. I'm not scared of doin a lil work though. I'm puttin a 3" body lift on so that will take care of my clearace issues I believe. Other than a lil wiring it don't sound too difficult.
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
Shimmed FPR
IN THE WORKS:
6" Mitre cut stacks
DP F5
Other toy
post #7 of 20 Old 02-24-2009, 04:08 PM
I was just saying that it would be a much simpler task to use the ZF-5 which is not a bad standard tranny to begin with. a fine one a that.
post #8 of 20 Old 02-24-2009, 04:13 PM Thread Starter
NOVAJOE105's Avatar
Right...I see what you're saying. IDK....I have driven several 6spds and 5spds and like the feel of the 6 better. I just found a thread on a rolled 6spd 4x4 so I'm waiting for a replay on buying the whole truck....haha
[/SIZE]
1995 F-250 4X4
7.3 DIT E4OD
Shimmed FPR
IN THE WORKS:
6" Mitre cut stacks
DP F5
Other toy
post #9 of 20 Old 02-24-2009, 04:32 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
How would you install the clutch pedal assy? I thought about doing this to my truck also so thats why i ask.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #10 of 20 Old 02-24-2009, 08:40 PM
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Save your money and build your Automatics! The built autos will cost about the same to do a manual swap, and the built auto will flat out OWN a manual truck of the same power, espcially from a stop.
-Michael
1997 F350: Regular cab, XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Tow/Street Truck
Swamps 200's, Modded H2E, HMR Street Puller, Fuel system, Swamps Programs
2001 VW Golf Four Door GLS, 1.9L TDi, 5 speed - Almost makes fuel
Sold: 2000 F350: Crew Cab, 7.3L PSD, 6 speed, Dually - Pulling truck
Dieselfever78 is offline
