Injector size question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-18-2009, 07:18 PM Thread Starter
I have a 97 cali psd, with it being already set up for splits can i just throw in a newer model set of injectors or use stage 1's for the sd? Also what size is the largest that I could effectively run with my HPOP?
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #2 of 5 Old 02-19-2009, 10:05 AM Thread Starter
bump for a fresh look.
Big Bird is offline
post #3 of 5 Old 02-19-2009, 06:58 PM
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
AD's(stock Super Duty) would probably be the max for your factory oil pump but you might try some 175 splits(biggest split you can make) that Swamps has. Super Duty stage I's would be single shots. As for the largest single you could effectively run would probably be in the 160c-180cc range.
-Michael
1997 F350: Regular cab, XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Tow/Street Truck
Swamps 200's, Modded H2E, HMR Street Puller, Fuel system, Swamps Programs
2001 VW Golf Four Door GLS, 1.9L TDi, 5 speed - Almost makes fuel
Sold: 2000 F350: Crew Cab, 7.3L PSD, 6 speed, Dually - Pulling truck
Dieselfever78 is offline
post #4 of 5 Old 02-19-2009, 10:04 PM Thread Starter
Are splits or single shots better for fuel mileage?
Big Bird is offline
post #5 of 5 Old 02-20-2009, 07:49 AM
Single shots are, and use less oil vs total ability to flow fuel. I.e. 175cc single uses less oil than a 175cc split.
-Michael
