HPOP - Ford Powerstroke Diesel Forum
Old 02-17-2009, 09:23 AM
Send a message via AIM to smokin95psd
HPOP
I am thinking about doing stage 1's and a 17* Super duty pump. How much is it to send a good 15* pump and a 17* pump to get the internals switched. Also if i do this am I going to have to do any fuel mods? will the stock OBS valley pump support stage 1's and the 17* HPOP.
Old 02-17-2009, 09:31 AM
Check out my post on the Adrenaline hpop or go to Dieselsite.com, this is the route I would recommend.
Old 02-17-2009, 02:11 PM
a truck
Terminator engineering will fix the drainback issue for you as well for a very good price, thats what they are currently doing with mine, and you wont need to upgrade your fuel system for stage 1s
Old 02-18-2009, 08:38 AM
injectors
I am kind of thinkin about the trannie savers that beans diesel performance has. They have a little bit less than stage 1's and are good with stock clutch etc. I want to know if it is good to do these, stage 1's, or DIY stage 1's. I want about 275-300 RWHP. I have an intercooler, 3" downpipe, 6 pos. chip (stock, 50, 75, 100, 140 ,high idle) single mass flywheel, LUK clutch kit (stock kit) , I want to know if i do DIY stage 1's will the truck still need a bigger HPOP or what. thanks guys
Old 02-18-2009, 08:41 AM
ADMIN AND TECH
truck will not have to have a bigger pump to run right
Old 03-17-2009, 02:03 AM
Send a message via AIM to strokenit Send a message via MSN to strokenit
sorry to ask this, but will someone tell me what exactly it is to send in you 15* and 17* to get the internals switched and what the drainback issue is?
