This sounds rediculus. - Ford Powerstroke Diesel Forum
Old 02-16-2009, 11:21 AM
I know how absurd this sounds, but where have you all routed the tube for the boost gauge through the firewall? I am getting my gauges in finally and of all of the write ups and step by step pictures shows that I have seen do not show this. If i need to drill a hole then I would like to be sure of the location so I don't hit something vital.
Any help would be great.
Old 02-16-2009, 11:24 AM
There should be a whole around your brake booster. There is a plastic piece in its place at the moment. yours a obs?
Old 02-16-2009, 11:28 AM
yep it's an obs. i went out to take a look, however I did not see any plug around the brake booster. maybe that is where my clutch master is bolted up?
Old 02-16-2009, 11:33 AM
what is a FPR shim?
Old 02-16-2009, 11:35 AM
Originally Posted by Norman9573 View Post
what is a FPR shim?
Fuel Pressure Regulator shim, it is basicly increasing the spring pressure in the regulator which increases the feed pressure to the hpop. or atleast that is what my understanding is.
FPR Shim Link.
Old 02-16-2009, 11:38 AM
ah, ok...do you know anything about turning up the fuel pump?
Old 02-16-2009, 11:40 AM
I installed guages this weekend in my 05. I drilled the hole from inside the cab there was no issues of hitting wires for me.
Old 02-16-2009, 11:42 AM
ok out comes the drill... good thing I have grommets somewhere around here.
as far as turning up the fuel pump, from what I understand on the PSD's you need to either rebuild the pump to a 17* or replace with a Super duty 17* hpop. I have not gotten there yet so I don't know.
Old 02-16-2009, 11:47 AM
Id just drill a hole. Sorry i didn't realize yours was a obs.
Old 02-16-2009, 12:45 PM
You're talking about two completely different systems.
I would assume by saying fuel pump you're talking about the fuel system. The 17* pump you're talking about would be the high pressure oil system.
