Modded 17* HPOP install has begun!
Well guys I decided to get started on pulling out my 15* HPOP so I could send that and my 17* HPOP in that I bought to be modded. I also got my modded IDM back and put that in today
![]() ![]() and pulled my chip out to get reburnt ![]() ***EDIT: Got the pump out now, finally got the bolt loose, pics are on page 4 Anyways, I did not get all the way done today, I am litterally two steps away but I cannot seem to get the 18mm bolt loose that holds the HPOP gear on, if anyone has any tips I would appreciate it. So here are the pics of the removal so far. Just getting started ![]() Next up I removed the fuel filter and drained the housing using the yellow lever you can see ![]() next up I pulled the intercooler pipes of an all the boots, if you dont have an intercooler just pull off teh y pipe ![]() When I pulled the pipe off the turbo I noticed that the o-ring was broken so Ill be getting a new one now ![]() Next using a 5/16" ratchet I undid the two bolts mounting the glow plug relay and pushed the relay off to the side ![]() After that I unplugged the sensor on the passenger side of the fuel bowl as seen here ![]() Then it was time to loosen the clamp holding the fuel bowl drain hose to the fuel bowl using a 1/4" ratchet. Then you can leave it on the bowl and it will wriggle off when you pull the fuel bowl out ![]() Next their is a heat shield covering the fuel lines, just pull that off ![]() This will expose the three fuel lines ![]() Using a 1/4" socket loosen the clamps holding the fuel line on, only do this on the passenger side top line and the line down below the other two Their are two fuel lines on teh front of the FPR ![]() Use a 9/16" wrench and remove both of them ![]() There are two 13mm on each side of the rear of the fuel bowl, remove both of those and the fuel bowl will be loose, there is also another fuel line on the driver side of the bowl, loosen the clamps on that as well. Once you undo the bolts start to wriggle the bowl off and the fuel lines will slide off, do not pull it out all the way though as there is still a sensor connected, once you work it out a little you will be able to see the sensor and then you can pull it off as seen in the center of this picture ![]() Then go ahead and pull the fuel bowl out ![]() Here it is with the fuel bowl removed ![]() At this point it would be a good idea to replace all the fuel lines that you loosened up becuase the old ones may be brittle, I know mine were. the two lines on the back of the bowl are 5/16" and the one on the drivers side is 3/8" ![]() and some nice new fuel line installed ![]() and the old brittle fuel line ![]() I had cut some of the old line to make it easier to pull the bowl off so here it is with all the old line off ![]() Next up I chose to pull the HPOP reservoir off so it would be easier to get to the HPOP gear, first off pull the cap off the reservoir and drain teh oil out, I used my own homeade pump Then undo teh two 13mm nuts holding on the bracket on top of the reservoir ![]() Next pull the plug off the sensor on top of the reservoir ![]() You will also need to pull these two plugs off the AC compressor ![]() Before pulling off the bracket there is still a sensor connected to a line, use a 5/8" wrench to undo that and then pull off the bracket Also undo this sensor on the back of the reservoir ![]() Then there are 5 bolts holding on the reservoir two are 13mm and three are 10mm, undo these evenly so you dont stress a bolt and then pull them out, then pull up on the resevoir and it will come out ![]() ![]() And the reservoir removed revealing the HPOP gear ![]() Next undo these two oil lines to the HPOP using a 11/16" wrench ![]() ![]() There is a plate that is RTV'd on directly in front of the bolt holding the HPOP gear in, undo that plate held in by two 8mm bolts ![]() And this is where I stopped for today, more to come! Last edited by Matt P; 02-26-2009 at 11:03 AM. |
gettin all your peices tied together for your big race
Nice work and write up so far Matt.
When I pulled mine, the 18mm was a "blind" removal, and a little bit of a pain. It came off OK, but when I put it back on I had to put a wrench on the crank pulley to keep it from turning while pulling on the torque wrench. Mine is an early '99, not sure how different yours is though.
Thanks Doug.
Unfotunately I just have a regular 3/8" ratchet down at school, no breaker bar or anything, Im guessing Im just gonna have to keep cranking at it to get it loose but if anyone has any other tips let me know, thanks! |
matt if u can get ur hands on a air impact that will due the trick. good luck though
![]() so I just need to keep cranking on it then til it gets loose?
to the 3/8 impact. If not you might not get it off. sometimes it's not a matter of holding the crank etc.. still. the pump gear might not turn but the pump shaft can turn inside of the gear. If that is the case you will need an impact. You can try to put a ratchet on there and then smack the ratchet with a hammer or something similar to give the bolt a "jolt". Maybe that will help break it loose...
yeah unfortunately I dont have acess to an impact right now, looks like Ill just keep workin on getting it loose
Hope you get it worked out.
