97 OBS boost ?
My friend has a 97 F-350 with a 5 speed manual trans. He is running a two stage programmer from Superchips and in tow mode he only sees 11 pounds of boost, sounds low to me
what should it boost stock? It is all stock except the programmer, gauges and a high flow muffler.
i hit 20psi on the highway this morning but that was on street tune from TW
stock obs boost is 15-17 psi,hes got a problem somewhere,check all turbo intske boots,up pipes any clamp that has to do with the turbo ,check it.does he get any black smoke?
how much boost can the stock turbo take
my turbo is stock and i hit 20.....at least i think i did
the gauge was bouncing all over the place
Nothing over 30-35 pounds.
On another note, you should be getting good over 11 pounds. You have a leak somewhere. Check all the boots, and get a TW with custom tunes and you'll see higher boost. |
Lots of guys here run 30+ psi no problem on their stock turbos, theres even a few hitting 40+ and there still working.
have been something else
40 pounds is to high. Maybe if they are driving an 03-04 with a boost fooler. But the 97 garrett should not hit anything over 30. Maybe once in awhile is ok, but not a lot.
