Clutch Question? - Ford Powerstroke Diesel Forum
Old 02-04-2009, 05:52 PM
Clutch Question?
I have a stock 5 speed transmission with a stock clutch. How are is it to put in an aftermarket clutch and which type of clutch is the best
Old 02-04-2009, 07:02 PM
Send a message via AIM to Dieselfever78 Send a message via Yahoo to Dieselfever78
Not too bad to pull trans and replace the clutch
Pull shifter/boot and 4x4 shift(has pinch bolt below)
Pull drive shaft(s) from trans/transfer case end
Remove slave cyl and have something to hold pressure on the rod
Remove inspection cover, add trans jack
Remove crossmember, unplug wiring
Remove bellhousing bolts and pull the trans out
Remove and replace clutch
Reverse procedure for install.
I would suggest either a LuK clutch or a Southbend clutch, definatly get a single mass flywheel.
-Michael
Old 02-05-2009, 05:52 PM
i've got a single mass south bend and i love it....grabs every time never slips and i have been known to drive my truck alittle ruff....i've done multiple boosted launches and it smells alittle funny when its burnin but man it drives nice....the only thing i have to complain about it that its big enough it lugs the engine right down as soon as it starts to engage....i only have to push maybe 4in to get it to disengage and it shifts great...
Old 02-05-2009, 05:54 PM
scuffs *****
Send a message via AIM to Tyler
The dual masses blow. I've heard nothing but great things about the South Bend singles!!
Old 02-05-2009, 05:55 PM
def convert to a single mass flywheel... Valair or SB are my 2 choices...
Valair has been making clutches for big rigs for years... so they are top quality products at a very good price.... you can find them here: ValAir Performance Diesel Clutches
Old 02-05-2009, 06:27 PM
CompressionIgnitionAddict
I put a Valair in my 99 and love it. Great clutch for a good price. Just my
Old 02-06-2009, 08:37 AM
i dont mean to hijack the thread, but i need a new clutch too and was eyeing up the Volair and was wondering if any one knows if the one with the HD hub is worth the extra money, they are both rated at the same horsepower and torque levels.
any opinions?
Old 02-06-2009, 02:10 PM
I got the HD hub with mine, I would think the hd hub would be better than the oem style IMO.
Old 02-06-2009, 02:16 PM
what he said.... they are a lil stronger...
Old 02-06-2009, 04:38 PM
I bought the Con OFE. I have yet to install it along with fixing the broken tranny but it is on my list of things to get done. Why did I go with a SB????? Not sure. If they are they standard that all are compared to then I just decided I wanted the best. Maybe I wasted my money. Not sure...JJ
