I/C info needed - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-27-2009, 06:24 AM Thread Starter
I/C info needed
ok, I got the I/C and pipes off an '00 F350 to install into my '97 F250
Where can I pick up the adapters to tie into my intake (Y pipe?) and turbo?
thnx,
boogie
Boogie's AutoRama is offline
post #2 of 4 Old 01-27-2009, 06:53 AM
Shaking the Bush Boss
CHUCK's Avatar
Check ebay....
Chuck
CHUCK is offline
post #3 of 4 Old 01-27-2009, 08:56 AM
cj41foleyisathief
Originally Posted by CHUCK View Post
Check ebay....
X2 look up turbo hose on ebay. Over a 1,000 hits
95 F350 CC 4X4 5 speed with some stuff
RC51 is offline
post #4 of 4 Old 01-29-2009, 10:35 AM
You'll need an early '99 Y pipe. That's the ONLY one that will work. And those factory pipes you got don't work well at all. You can make them work by extending them but the way they run through the engine compartment they are tight and rub on a ton of things. If they are aluminum they will likely get a hole rubed through them like mine did when I first installed the IC on my truck.
Also what else do you have done to your truck? Don't expect any power gains from the IC. They don't add power. Just lower EGTs. If your EGTs aren't getting out of hand now you are just going to make the turbo take a LOT longer to spool up. Unless you have bigger injectors I'd look at getting a smaller turbine housing to try to regain some of your spool up time.
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors, Intercooler install kit-GTS Motorsports
Crower rods, H11 Head studs, Cam, Chip Diesel Innovations
Gen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from Power Hungry
Current Chip Tuned by me!
Transmission BTS
custom turbo kit with HX40.
12.683@105.65 in 1/4 mi!
466hp #2 only
805hp NČO
Yeah I can keep up!
gtspowerstroke is offline
