sd hpop - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-21-2009, 04:58 AM Thread Starter
sd hpop
I may have found a 99superduty hpop. will it be a 15 degree or will 17 degree. i wanna upgrade from my stock 15hpop.
1995 F250 7.3 turbo
3 inch dp into 4 inch exhaust
tymar intake, Isspro boost, pyro, tranny temp gauges
tow and go shift kit, DIY electric fuel pump system with fuel pressure gauge,bronco tank mod
kcm ss hpx line, stancor gpr, 203 thermostat, 03 starter
TWchip 6 postion daily,econo,tow,street,xtreme,highidle
Banks intercooler and pipe kit,Idm Mod,CCV Mod
Plant drive wvo kit(hotfox,vegmax filters,26fphe, vegthermmega and gauges for cooliant and wvo temp)
Dana 60 front axle swap
7.3TurboDiesel is offline
post #2 of 5 Old 01-21-2009, 07:27 AM
IHwelk49's Avatar
do you have the part # for it?
96 F350 Crew Cab
Tymar Intake-Intercooler-Beans Dom 66 turbo-
5" stacks exhaust-Beans Stage II's-TW chip 17* HPOPSD Electric Fuel
4" lift 18" Eagle alloys
Fully Built Auto
IHwelk49 is offline
post #3 of 5 Old 01-21-2009, 07:29 AM
FordCowboy's Avatar
If you can check the build date that should give you a good idea. Early 99's had the 15. Otherwise part number.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #4 of 5 Old 01-21-2009, 07:33 AM
IHwelk49's Avatar
the early 99 models still used the *15 pump, make sure you're getting the right one.Diesel Specialists Inc. - Diesel performance and repair parts for chevy/gmc, Dodge, Ford diesels. this place has the pumps at a pretty reasonable price
96 F350 Crew Cab
Fully Built Auto
IHwelk49 is offline
post #5 of 5 Old 01-23-2009, 04:06 AM Thread Starter
here is the part number Cust (1P) 1831022C96 how do i go about checking
1995 F250 7.3 turbo
