fuel and oil upgrades
does the sd hpop and the superduty fuel system go on a obs truck with out any modification to make it fit/work???
any one...
Yes the SD *17 HPOP goes right on and I believe the fuel system does to but not positive so heres a
for ya
You will have to change HPO res. to mount a SD fuel filter bowl to an OBS. Honestly I wouldn't use anything from a stock SD fuel system, not as an upgrade anyway.
-Michael |
yeah doesn't sound worth it for the SD fuel sys
Hpop is a direct bolt in. Fuel system not so much.
The fuel system would be a mild upgrade as far as the pump goes. I'm running a stock SD fuel bowl, though I have it remote mounted, and I'm running 350cc+ B codes, made 500+ hp and haven't had an issue maintaining fuel pressure with it. If you had the fuel bowl and all the lines going to the heads and the SD HPO resivoir it'd all bolt directly up to the engine. The electric fuel pump will need to be custom mounted and you'll have to wire it up. |
thanks for the imput. that info was greatly needed. so what would be a good upgrade for the fuel situation???
well for the upgrade for the fuel system, There are some places that sell kits. Beans, Diesel Site, and Swamps. Don't know much about Swamps kit, but I do know that Beans and Diesel Site's kits are good. I am saving money for one and hope to have it done in the Spring
