stock HPOP?
I am dropping in stage ones with upgraded fuel (raptor pump). Will I need to upgrade my hpop? If so is it as easy as getting a SD hpop? Or what would you recommend?
i hear alot of guys getting a stock hpop off a 99. dont know if it would help you but heres a
Yes, you want to get a stock 17* HPOP off of a late 99-03 truck. Right now you have a 15* pump, and the 17* is a great upgrade. It's a direct bolt-on and I noticed a HUGE difference in top end power when I switched. With swap is easy and it's definitely an upgrade.
how about a cross over oil tube? Is it needed or will just the hpop being bolted on be enough? Thanks for your help
what if you have 90cc injectors and switch to a 17* hpop?
will you notice any difference? |
psd
if you put a 17 degree hpop on your obs you will get alittle more top end and it has alot to do with your chip too.
If your looking for one we have them here at Welcome to Outlaw Diesel :: Home |
-Michael |
what is a cheap injector up grade for an OBS?>
DIY-injectors.com
The two words, cheap and injector, just don't go together when talking about any Powerstroke pickem'up. Unless of course, you follow the above link that cliford gave ya.
