intercooler manifold
i am in desperate need to buy the banks manifold to adapt an intercooler to an OBS truck. I just need the two pieces for the turbo and the intake. any help? i will take banks hypermax or any other brand. thanks
Call banks or dpppower.com?
Why dont you buy an early 99 spyder? it works fine. |
does it work with my factory filter housing installed? if so i am interested. please help asap.
yes it will work. I used early 99 spider pipe and super duty pipes(fabbed up a little). will also be able to keep you filter housing
here are the number parts: Early ’99 Y-pipe: F81Z-6K889BA Clamp (Y-pipe to 94-97 compressor): F81Z-8287DA or M/craft Service Part #YF-2488 2 Coupler (Y-pipe to 94-97’s 2” intakes): F81Z-6C640FA (2-3/8” to 2” reducer) Last edited by CELAYORK; 12-31-2008 at 10:00 AM. |
If you get the Ford spider, you will need:
1 - 3/8 NPT allen plug 2 - 1/8 NPT allen plugs Also not a bad idea to pick up a new turbo outlet O-ring. Some like to use the Navistar gray RTV instead of the O-ring. The SD spider will have two nipples sticking out that will need to be removed. Drill (forgot drill size) the holes out so you can tap it out to 1/8NPT. I'll post a pic of it installed tomorrow if the weather is decent. Billy T. gnxtc2@aol.com |
